Nutball
- 12:18 PM
- Oct 31, 2018
- Mt. Juliet, TN
I'm going to leaf port? lawn port? yard port? this 265L because nobody should wear a backpack blower that is outperformed by a bottom of the line hand held.
The way I figure it, to modify a blower it is best to start with a model that has a narrowing nozzle tip, because that will be the first part to go. Once that is gone, the tube diameter becomes larger allowing more volume to flow. This reduced restriction that increases volume decreases fan speed by putting more of a load on the engine. Then you increase engine power to make up for the lost rpm and add a little more.
First I got some reference numbers:
10,920rpm stock
10,450rpm with the small end tube removed.
11,400rpm without air filter
Around 13,560rpm max with the tube blocked, so I don't want to exceed that rpm with a blocked tube by much after the mods, so the fan doesn't break.
I will assume, but could be wrong, that reducing the ignition timing will be an effective way of reducing the max rpm without affecting the normal running rpm anywhere near as much if I needed to dial it back some.
Next I will open the muffler and check both the loaded rpm and rev limited rpm to see how sensitive the max rpm is to change.
10,920rpm stock
