GBertolet
I am working on a B&S 12H802 1767-E1 engine. It's from a Toro Personal Pace mower. It's using oil, along with low compression. The engine is torn down. The cylinder measures 1.682, and the piston is 1.672, both the old compression rings gap at .050. Being the cylinder is towards the upper end of tolerance, would it be advantageous to get .010 rings for this engine?
More bad news, I had to destroy the drive pulley, getting it off the crank. The setscrew was sandblasted, so there was nothing to grab with the hex wrench. It was very hard drilling, to get a bite for the easyout. Soaking in liquid wrench, and some acetylene torch, finally got it out. Even with the setscrew out, that pulley would not budge. It was rusted solidly in place. No room to get a gear puller behind it. I had the idea of sliding a piece of 1" pipe over the crank, then welding it fast to the pulley, then welding a 5/8" nut, to the other end of the pipe, and using a piece of 5/8" threaded rod, double nutted on the end to make my own puller. Still no good, even when heated with the torch. I finally gave up, slitting the pulley, down to the crank, lengthwise, with a dremel cutoff wheel, both top and bottom, cutting pieces of the belt flange off also, to get the puller behind it. More liquid wrench and torch, and it finally began to move. Eventually it came off. Add the cost of a new pulley to this job. They are not cheap for this mower.
