- 9:23 AM
- Jun 5, 2016
- Northwoods of Wisconsin
Had a 550xpg come back in locked up, seamed odd for the amount of use it saw.
Upon disassembly it was discovered that a tiny screw had found its way into the cylinder.
You can see it as I found it in this picture.
It took a little bit of detective work to find where it came from.
I believe that a drop of loctite will be standard procedure for these two screws in the future.
Somewhat fortunately, this cylinder is not badly damaged, a little bit of beveling, a new piston and screw and it will be back in business.
This is not to say that it could not have turned out worse and the cylinder could have been ruined, which is a much more costly proposition.
