Nylon filter for winter, or just spare felts?
wildroamer
Winning!
4:02 AM
Vermont
Hey gang,
I have a 562xp that I want ready for possible winter use, and would like thoughts on switching to the yellow 44 micron nylon filter for below freezing conditions.
I have the removable plug to warm intake air, as well as the cover for < 23° F. Husqvarna recommends one of the nylon filters for winter/cold use, but I wonder about increasing the crap that gets inhaled by the saw.
Anyone else in cold climes, dealing with hardwoods, often dead?
Thanks
super3
4:02 AM
Indiana
Running the nylon filter makes it sound like when you turn the top of the air filter cover over on anything with a Q Jet carb.
wildroamer
Winning!
4:02 AM
Vermont
I have done very little cutting in real cold condtions, and hope it stays that way. Good to hear you haven't had issues with icing or anything, thanks.
weedkilla
5:32 PM
lobethal, South oz
Opposite problem here, 100+ most days but also cutting dead filthy dusty wood. I'm having better results with an oiled nylon than with a dry felt. No fines getting into the inlet with the mesh.
Opposite result of what I was expecting.
wildroamer
Winning!
4:02 AM
Vermont
Super3 not sure what you are referring to there, but assume you are talking about increased noise from the air being sucked through the larger openings in the nylon filter? I hadn't thought of that, but doubt it will be too noticeable after Mastermind tinkers with the muffler.
wildroamer
Winning!
4:02 AM
Vermont
Missed your post weed. That's interesting, does the oiled filter require a lot more cleaning? Seems like it would collect a lot of dust and such.
super3
4:02 AM
Indiana
Yep, you got it.
weedkilla
5:32 PM
lobethal, South oz
Cleaning is easy. I give it a squirt of brake cleaner and a squirt of fresh oil at night.
Just knock off dust at lunch.
I've forgotten to clean and re-oil, two full days work and all was fine. A gallon a day is about normal.
davidwyby
Rural desert logging
1:02 AM
Extreme Southeast CA
Super hot dry dusty here...nylon or felt? OEM or AM?
Thinking OEM Felt.
Thanks!
Stevetheboatguy
3:02 AM
Nw IL
Felt for work. Nylon for play. I'm sure there are cases where the flocked filters will freeze. But I've been cutting the last two weeks at anywhere from negative 10 degrees in the am to 5 above in the afternoon. Haven't had any issues with ice. Although I have been running xpg's and a heated Makita. If that makes a difference.
Steven
Superwd6
4:02 AM
Stirling Ontario Canada
Hey gang,
Thanks
My 576xpg came stock with black 88 micron I think. It would barely stop the rocks so I replaced with yellow 44 filter . 10 or so years ago now and have never ran flocked filter. Just replaced filter last year
10:02 AM
Felt filter doesn't care whether it's hot or cold.
I run most of my saws with factory stock felt filters year round, two are running fine nylon filters, NOT the coarse nylon "winter" filter.
