Jon1212
Birch! Please.....
- 11:01 AM
- Dec 29, 2015
- Utah, unfortunately.....
If it'll work get it cumin my way ASAP
I dont have the time to log on here very often Jon so shoot me a text if it'll work and I'll send you some green.
I think those wires are supposed to be hooked up.I knew the 390's were pretty much a big bore 290, I wasn't sure if the same was true for the 291 and 391.
What's throwing my off is the 271
Here is the coil off the saw that I'm working on.
Randy's legs work better than this coil does
Are you too busy counting your chickens, before they hatch?
I know there's 2 different coils for these saws. I'm not sure on the PNs. I'm also not sure if there is a SN break to determine which coil you need or if one coil is an updated coil that straight up replaces the other.
Basically, I'm not much help here. In fact I'm sorta useless in this regard. Cheers.
Iirc the 271 and 291 are the same chassis and then the 311 and 391 are there own.
So it should work.
Hit up Ray for an iplSo this coil probably won't work then if the 281/291 are one series and the 311/391 are another series
