Mike in Montana
OPE Member
Hi everyone, first post. Seems like a lot of knowledge here.
Several searches didn't turn up anything useful so I'll outline my situation followed by a question.
I bought a Neotec 070 clone as a project/milling saw. Stock it ran OK but was sluggish and seemed like it wasn't revving 100%. I know they are low rpm saws but still...
It had .050" squish so I deleted the base gasket and tried again. It definitely improved the torque and response but it started popping under load. Lean or detonation? I couldn't tune it out...
I pulled it apart to inspect the piston and cylinder. They looked fine other than the piston had very black carbon like it was rich.
While it was apart I cleaned up the ports, raised the exhaust 2 degrees(106 to 104) and cut 2 degrees off the piston skirt increasing the duration to 152. I also pulled the carb apart and blew everything out and checked the meter lever. I adjusted the meter lever to richer and buttoned the saw up.
Again the saw improved on the bottom and would rev up but just start to cut and bog out like it is starving for fuel. Again, I can't tune it out. I've pulled the carb several times and adjusted the meter lever both ways and adjusted the high and low as rich as possible but it pops and bogs just after reaching the powerband. It is so rich on the bottom it barely idles but acts lean on top...
If I over richen the high and lean it out again it responds but then bogs like it's starving.
The carb has a Tillotson part number on it but I can only assume...
I don't have a pop-off pressure tester, could it be the meter lever spring?
What am I missing? Is their any performance tricks for these carbs? High jet/nozzle to small?? Should I swap it for some other carb? The 090 has the same carb so someone has to know something about them?
If I can get this figured out, I have an 090 top end to play with next.
Any advice for the carb or 070/ 090 performance is greatly appreciated!
