BigRed96
- 1:15 PM
- May 22, 2016
- New Richmond, Oh.
I rebuilt a MS200t for my Father to give him as a Christmas present. Currently I can get the saw to pop with the choke on, then I can get it to start and run on high idle for a second or two. A little history on the saw. I bought the saw doing pretty much the same thing and tore it down. I did not split the cases. I replaced the seals, put in new piston rings, cleaned the carburetor in my ultrasonic cleaner and rebuilt using a kit. The impulse and fuel line are brand new, however I can't remember if the filter is or not. One problem the I do have is the damn flippy cap on the fuel tank leaks. I have pressure tested the fuel line and visually checked it for leaks and it seem good. Also the fuel tank vent is brand new and seems to be function. I put oil in the impulse line and it blows back out when you pull the starter so I think its clear. I am pretty good with the carburetor rebuild having done a bunch of them. At this point I don't know what else to check. Btw also vacuum tested and pressure tested the saw and it passed both test. I also inspected the intake line for cracks and didn't see any. I set the flywheel gap using the business card method. Anyone have any suggestions?
