Do you lot in the states have this on the market I just bought some to try because my regular supply is getting very low and need to find something soon it smells nice smells like a bag of lollies be interested to see how it goes fumes wise .
also interesting absolutely no dye so you're not going to know whether it's mixed with your fuel or not .
Cheers
I use it here in Ireland, and it oddy has a red hue to it, I can
tell its mixed as the fuel I use is very pale / clear.
Have only started with it, so not sure how good or not it is,
am using it in small saw at 40:1, it is not leaving the same amount
of oil on the piston sides as the HusqvqrnqXP or Echo powerblend
I think it would work at 50:1 as it has a good body to it, I found I
had to shake a lot to ensure it was mixed, it lay for three months
and did not separate, it doesnt mix / absorb water,
this is the main reason I use it, it should protect bearings when the saw is laying up, thats my main reason for using it.
Its also the cheapest of the well spoke of oils you can get here, motul
and maxima are more expensive here, Echo Powerblend is cheaper
and runs real clean too but its a semi synthetic oil.
The Mobil1 2T Racing gives off no bad odor that I found.
Just in case someone reading this does not know there are two versions,
the 2t Racing above,
and Mobil 1 2T , note the lack of Racing in the name,
it is not FD rated and is cheaper, the price will alert you alone.
