Your humble student
OPE Member
Knowledgeable ones
I am your student here. Purchased and assembled the Chinese clone MS660. I really enjoyed the build. I have a specific question concerning port timing and what to do to fix it. I mounted a degree wheel and the port opening measurements are as follows.
Intake 95 degrees ABDC (how to get to 80?)
Exhaust 95 degrees ATDC
Transfer 125 degrees ATDC
making blowdown 30 degrees
Squish 0.032” with base gasket
The question is do I simply grind the floor of the intake to get to 80 degrees?
Have machine work done to the base and squish?
Thank you
Thank you
