Maybe one of the guys can chime in who have parts smart. It's possible the sprocket for your saw is used on another saw. You can cross reference it on Ebay if you like.
Yes $63 is way high. Check a local dealer for price reference for OEM. That will give you a starting point to shop other places.
I believe the 241 uses the same as the MS 250. Worst case I can pull mine and check the number on it. Be advised going from the 6 pin spur to 7 pin rim makes fitting the standard chain size on very difficult and makes it almost impossible the powerhead if you get bound up. I run a 56 link chain on a 16" bar vs the 55 link. This makes it a bit more difficult to share chains with my MS201T.
The MS 250 does not use the same rim sprocket kit. The rim sprocket kit for 3/8 P is 1143 007 1002. Take the original one and be done with it. It`s right that a chain with 56 drive links is needed for a 16" bar.
