I Know Something
- 7:13 AM
- Dec 23, 2018
- Fairmont, Minnesota
Swooped right in and saved his ass.
This might help with the handle.
To say that I didn't have to have a puller to pull the crankshaft through the bearings was a surprise would be an understatement.
Ive got one of those sitting in my garage half put together.. Runs absolutely great. But does not turn off once its started. I've had the handle apart probably 8 times. Gave up and now it's just collecting dust
If I remember correctly, I left the carb loose,then used a pick with a small 90* bend at the tip. I may have left the handle linkage side not fully fitted in the hole.I'm currently just having an issue getting the linkages to the carb to stay put. They keep coming off and falling apart. I have tried the choke operation. Still trying to get the throttle to work.
Yep. Got that. It's the ones touching the carb its self.The horse shoe thing hold stuff in place.
As long as it works! I'll try that tonight.If I remember correctly, I left the carb loose,then used a pick with a small 90* bend at the tip. I may have left the handle linkage side not fully fitted in the hole.
