ZukiRyder400
Breaker of recoils
- 8:12 AM
- Apr 11, 2018
- Your bum
So today, I got into my 562 to see why it was running so lean, come to figure out my thinner base gasket that I made didn’t seal correctly at the intake side because the base wasn’t completely flush with the cases . So luckily I had a spare cylinder and had gasket sheets that were the same exact width as the stock one. So as I was getting it back together I notice that the other junk 562 has 6 screw cases. Checked the main bearings, and rod bearings and all felt good. So I swapped all of the good parts to the 6 screw cases, added some more oil to the gas and started er up. Ran real rich because of the oil that I put in the cylinder upon installation and the extra oil I put in the gas. I shut it down and try to start it back up but I shear the flywheel key. So I took off the recoil, indexed it and gorilla tightened it down( didn’t advance/retard the timing). So I got everything put back together, tried to pull it over and the handle just snaps out of my hand like it had 200lbs of compression. Pulled it over nice and slow and it felt worlds easier but when I tried to give it the gusto, it backfires almost but it wasn’t gunshot loud but it was a big poof. I said “What the H word?” and I saw smoke coming from the muffler. And I took off the top cover and the air filter and there was exhaust smoke coming from the intake as well. Took the spark plug out just to make sure there wasn't a fire in the cylinder. This is very strange to me any help would be greatly appreciated.
