Magic_Man
Oh Yea !
- 5:28 AM
- Dec 4, 2015
- SE Ohio
Hey fellas, life’s been a real pain here as of late. It’s starting to sound like the makings of a country music song. Finished up a divorce a few months back, got laid off from work right before the holidays, and now my truck broke down. You just can’t make this stuff up, really, you can’t. So I’m offering up the last of my saw hoard, the stuff I was keeping for myself. Hopefully someone here can put it all to good use.
1) SOLD MMWS Husqvarna 181\288 this saw was completey rebuilt, had a nos 288 top end put on it before sending it off to Randy to work his magic. Has a velocity stack, and a brand new oem carb installed. Does not have a working chain brake, it has the old wire handle style clutch cover on it. I installed one of those tac/hour meters when I got it back from Randy and I am certain it has less than 20 hours in it, probably closer to ten. Saw was always run on VP94 40:1 fuel.
$650 shipped PHO or have a 32” bar and chain that could be added.
2) SOLD Husqvarna 272xp this is an early predecomp saw, its really clean. I haven’t had it long, ran a couple tanks of gas through it in the spring. Everything seemed well, no obvious problems. Can pull down and get comp #’s and piston pics if needed. Better pictures of saw to come soon. It’s the saw closest in the picture, saw in back is the 288 above.
$400 PHO , have the 20” light and tough that could be added if wanted.
3) SOLD Stihl 460 Magnum project, ported by @mdavlee Mike Lee. This is a saw I was going to build and keep for myself. Overall in pretty good condition, was used by a homeowner. Only bad I see is the tank was burnt at some time, but doesn’t affect operation.Piston was scored so I tore it down and sent the jug home with Mike Lee at one of the get together. I have several new parts to finish this build including a aftermarket rubber kit, aftermarket dual port muffler cover,aftermarket bearings, aftermarket intake rubber, Aftermarket non flippy flippy cap replacements, Aftermarket gasket/seal kit, Meteor piston, and OEM piston pin bearing and circlips. If Mike Lee approves I can send PM pics of the porting. All small parts should be there to put the saw back together. As far as I know Mike isn’t building saws anymore, here is your change to get some of his impressive work.
$400 shipped for all of it
4) SOLD Husqvarna 350/346 project. This is a super clean 350 that I dyed the tank, top cover, and recoil black. Cases are in great shape with no cracks or burns. I have an new OEM 346xp cylinder and piston kit along with an OEM intake and screw clamp to fit. All small parts should be there to assemble saw as well as the 350 closed port, quad transfer cylinder with removeable covers. Piston was scored, but cylinder should clean up easily.
$250 shipped
$250 shipped
