Holy smokes that's a car load of saw Bryan![]()
That is a monster. We're there saws made larger than 200 cc? What do you think it is going to take to get it running?
Very very nice looking Model 5 - that will be a great original machine when you have finished with it!
Chris
Yes, there were much larger machines than 200cc's.
Regarding getting it running, it needs the normal stuff (seals, fuel line, carb work, ignition work) and the top two rings are frozen.
and then there is the shape of the top of the pistonIf you look closely at the shot of the piston with the tape measure, you can see that in lieu of locating pins, when machining the ring groove, they left a bit of meat in the groove the locate the ring ends. Pretty cool stuff.
