Makita DCS 6401
TomF
12:20 AM
North Carolina
Will this model saw accept the 7900 p/c and are there any special tricks to doing it?
Thanks,
Tom
TomF
12:20 AM
North Carolina
Thanks again for your insight.
Tom
Steve
Excellence!
11:20 PM
Thanks,
Tom
Only thing to watch out for is the decompression valve location. If you are putting a true 7900 top end on it, it's a direct swap. The 7910 top ends have the decomp on the top of the cylinder and you will need a top cover to match.
SOS Ridgerider
Muffler Modded Member
12:20 AM
Central CT
The decomp valves themselves are also different lengths. The left side decomp valves are longer than the top right ones. If you have a left decomp top end now and put a top right decomp top end on you’ll need a shorter decomp valve.
I have put the shorter ones in the left decomp top ends before, and can’t tell a difference in performance, but that’s just me, and some may disagree.
I usually replace the decomp valves anyways when I replace a top end.
Just my $0.02
