nick890
New OPE Member
- 5:49 PM
- Sep 3, 2024
- Dayton Ohio
I have 2 Echo SRM-225 weed eater. I was having issues starting them, so I first checked for compression. One would give me about 80psi and the other was about 70. I disassembled and opened the cylinder to find what I would consider to be minimal normal wear. I checked that the ring was free to move, and I cleaned the inside of the cylinder and the piston itself. It had little to no effect. I decided a factory Echo piston and ring may help enough to get some more life out of the weed eater, so I bought one for about 45 dollars and put it in. My compression actually dropped to 55psi. I am not sure how it could become less with a brand-new piston and ring. I attempted to install the new piston in the other weed eater, and it also would only achieve 55psi. I really can't understand how the compression is so low. Is there anything else that can affect compression? I have photos of the original piston and the cylinder to show that these are not scored up and to me look to be in overall good condition.
