Log holder/saw bucks pics
Wood Doctor
Edwin
3:32 AM
Omaha, Nebraska
I really like this one that I made with 7/4 hardwood. It's built low to the ground, but that makes it easy to load. The six cross legs are identical and the two horizontal supports also match each other. Screws hold it together.CrossBuck03.jpg
There is a slight taper added to the the tops of the cross legs. The legs are notched to accept the horizontal supports and the supports are also notched so that all the pieces lock together to help out the screws. Rock solid.
Johnny2186
4:32 AM
Ohio
Thanks for posting a picture for a reference!
Wood Doctor
Edwin
3:32 AM
Omaha, Nebraska
Here are the plans that I used to build it:
Note that all the pieces are even the same length, horizontal or vertical. So, you can hardly miss. If you want to make it taller, just increase the length of the legs. I use this sawbuck a lot and have made them for friends.
mdavlee
Hillbilly grinder
4:32 AM
TN
I built a stand that will hold 2 12x12 side by side with an edge to tighten them into so they don’t move. It’s all 2x2” angle iron with bracing. I put a 24” ash log 12’ long on it once and it didn’t even flex. Base is wider than the top and offset to be more stable as well.
