Dave Sr.
- 4:46 AM
- Apr 27, 2023
- Anamosa Iowa
Hi everybody I'm new to this forum. I'm building a log cutter as I'm too old to run a chainsaw like I used to. I run a small manufacturing business and heat my shop mainly with wood. A couple of years ago I had 10 big oak trees taken down that were too close to my house and I kept all of the logs and limbs probably enough wood for at least 3 Winters but it all needs to be cut into firewood size pieces. So I decided to build a machine to make it easier. I'm using a Stihl 034 chainsaw, a air over hydraulic system to move the saw, 2 12v winches to move the log cradle, 1 4000 lb. to move the log forward and a homemade winch to move the cradle back. The chainsaw is moved by a 2.5" bore cylinder that I built that connects to the primary tip plate, the chainsaw is mounted on a secondary plate that hinges on the primary so only springs apply pressure to the saw. when the springs stretch about 2 inches the secondary plate trips a limit switch that closes a solenoid valve shutting off the oil to the cylinder. When the saw finishes its cut it trips another limit switch that shuts off air to the throttle air cylinder, closes the oil in valve, opens the oil out valve, opens the air valve that applies air to the top of the cylinder to raise the saw up. Another limit switch switches the air off to the cylinder when the saw is in its up position, The log is moved ahead for the next cut and a switch on the control box starts the next cut. The saw has a 20" bar so it will cut through a 19" diameter log. The winch that moves the log forward has a wireless remote so I can set the log on the front roller and then bring the log cradle ahead under the back of the log from inside my skid loader.
I am now working on installing the gas tank that connects directly to the carb. and an oil tank that connects to the oil pump in the saw. Then my next thing will be install an axle and a tongue so I can move it in and out of the shop, Then mount the pressure and dump hydraulic tanks which are made from two 20lb. LP tanks. This site only allows me to attach five pictures so if you have any questions or suggestions please contact me by message or reply to this thread.
Thank You, Dave Sr.
Thank You, Dave Sr.
