Wasga
Active OPE Member
I have a Kohler engine that will crank but won't start. The engine had a bad head gasket, so I changed the gasket, lapped the valves, and did a general cleanup of the head. I also installed new lifters since I had the head off. After all of the work was completed, I had 75# compression. The valves were moving and everything else seemed fine. The motor will not start. It is getting fuel, spark, compression, and the timing key is intact. I am at a loss on this one. Any advice?
CV15s-41537
CV15s-41537
