Deputyrpa
- 11:59 AM
- Apr 27, 2017
- Fort Ann, NY
Looking for an un-scored cylinder for my Jonsered 920. Thanks.
OK. I'm convinced. PM on the way.I have a nice one, There were 2 cyls for the 920
one was open port and the latter was closed
like the 910E
I have the open $85,oo US funds
Yes. I got one from Northwoods Saw. It's a VEC, which appeared to be good quality.can you still get a piston?
( spike 60 ) can tell you
also I,m surprised that the open port cyl
is considered stronger, isnt it usually the
othe way around?
I was planning on keeping them as backup, but I may reconsider. I was also going to try my hand at porting the cylinder to see what I could get out of it.I may be interested in the piston and cylinder if your just going to chuck them ?
Ernie
I popped the jug today and saw that the case is NOT notched.I believe all the 920 cases were notched like the 930's ...at least the few I have are .
How bad is your 920 cylinder ?
Ernie
That's definitely odd ...I haven't seen a 920 that wasn't .I popped the jug today and saw that the case is NOT notched.
Nope.Is it possible that can be a 820 ...
Ernie
There ya go ....good dealWell Ernie, I was wrong! I measured squish this morning and decided to do a gasket delete to bring it down to under 40 thou. The pic I took last night was just a peek thru the front. After removing the cyinder I could see that the gasket was covering up notches! Here's a pic after I removed the gasket. I'll be dipped!
