Ignition system
Aggie2012
6:52 PM
Texas
Would some of the fine gentlemen on this forum be able to explain how this ignition works?
It's from an 015l.
I tore it down to here and don't know what to do. I've seen updates for this old style ignition but it sparks just fine.
However, I have to use the choke to kill the engine.
It seems much more complicated than the new saws that only use a coil.
Terry Syd
10:52 AM
Comboyne, NSW Australia
Just an old style points ignition system. If it is sparking just fine, then the problem is not in the ignition system itself (corroded contacts, blown capacitor) - it is in the grounding out of that system when you hit the kill button/switch.
Find the kill switch and work your way back, maybe there is a break in the wire or the switch is corroded.
Aggie2012
6:52 PM
Texas
I sure appreciate yalls help.
I will try cleaning up the area around the switch and wire. It was working fine up until last weekend so I'm hoping it may be as simple as that.
-Travis
Fish
6:52 PM
Manton Ky.
The black slide just depesses the spring to touch a nub, which grounds the ignition out{If memory serves me correct}. Just buff all of the parts with emory cloth.
Poleman
4:52 PM
Rapid City,S.D.
You'll be GOLDEN if you follow these FINE GENTLEMENS advice!!! It's in the stitch!!
Aggie2012
6:52 PM
Texas
Thank you sirs for shedding some light on this. I am quite "green" yet. I will be sure to let y'all know the outcome when I get back to it on Saturday.
Poleman
4:52 PM
Rapid City,S.D.
Lots of GOOD advice and people on here.... stick around and you won't be "green" for long!!!
