SOLD Husqvarna 550xp mark ii
husqvarnaxpman
4:01 AM
USA
Low hour Husqvarna 550xp with brand new updated crank and crank bearings. Brand new piston and air filter. The cylinder looked brand new. All Husqvarna oem parts. Nice looking saw. Sold power head only. $400
400hp
Active OPE Member
4:01 AM
ON, Canada
I see that this is sold, but can you tell me more about the updated crank and crank bearings? I have a 2022 but I want to make sure it's updated if need be.
Thanks
husqvarnaxpman
4:01 AM
USA
This saw had a small nick in the top of the original piston. The bearings looked fine one the cases were split. I know the earlier mark ii had bearing failures but I believe they will be all ok as long as you run at least 40:1 ratio.
400hp
Active OPE Member
4:01 AM
ON, Canada
Okay thanks! .... makes sense. I just run vp at 40:1
Since my saw is a newer one I'm sure it'll be fine.
