Matt D
Hey Guys, so I'm new to the chainsaw scene but not new to 2 cycle motors, messed with a lot of snowmobile stuff. So I got a 51 that ran but had low compression, took off the cylinder and both the piston and cylinder were scored, ordered a 46mm top end and cylinder for it from china and received them today. After reading and watching some videos I'm contemplating doing a base gasket delete on the saw using some yamabond 4. I used the solder trick to measure squish, I measured in a few spots and got .035-.036 for squish, this seems like a lot as I read the ideal amount is .018-.020. Now I don't have the equipment or knowledge to cut the cylinder down or anything like that to get those squish numbers so is it even worth it in this case to do a gasket delete? Thanks for any help.
-Matt
-Matt
