t4driller
Daddy Day Care
- 1:20 AM
- Feb 23, 2016
- Southwest pa
I have for sale a husqvarna 359xp. It's in nice shape but has a couple scratches and scuffs from normal use. The bottom of the case under the chain catcher has the most wear/ damage. There's no cracks in the plastics or stripped holes. I did a base delete and port work. Used a hyway piston after dropping the oem piston and breaking a piece of the skirt off. ( 2nd time this has happened, sucks not having a thumb that works or I can feel with). [emoji17] i was gonna buy a meteor to use but after measuring the hyway piston it was almost identical to oem. The pin to crown height was the only difference. .002 different. I installed a caber piston ring, oem pin and clips. Cylinder was very low hour, original piston still had all its machining marks. I used Hondabond ht for sealant in place of gasket. Has the 199 carb on it that I put a new kit in and drilled a hole in the cover. Has a metal 372 style intake clamp. Muffler has a second port with 288 style deflector. Comes with oem dual felling spikes. Selling as pho $425 plus the ride PayPal friends and family or add 3% for fees. I also have a bar and chain I could get rid of for extra if needed. If you have any questions just ask. Ill try and get a video of it running toady or tomorrow. Thanks
