husqvarnaxpman
Husqvarna 350 parts came from a low hour great running saw with good compression that leaked bar oil from the seem of the crankcase. 45mm cylinder and piston. Exhaust side of cylinder is in excellent condition. On the intake side you can see two lines above the intake. The intake on the piston looks good, but on the exhaust side there is one line you can feel. The crank and starter cover are in great shape. Top cover has a burn hole in it from the muffler. Parts should fit Husqvarna 340,and 345 also. $50
