SOLD Husqvarna 288 stuff
how57
It’s a city! Not a smoke!
3:40 AM
Weed Ca.
The cases are ruff. But usable. The AV mounts are good. I’d like to trade for 266 stuff. I need AV mounts. Large and small. I’ve got plenty of tanks and crankcases.FE9904BC-7383-44EC-AC4C-9F5704A2DECA.jpeg1E155DDF-A33F-4EBD-B9E2-325FEAA24B16.jpeg
exSW
'Cause Thomas is a poopyhead
6:40 AM
United States
I got a few new ones I think... Anything else? I think I have an older mag clutch cover with no brake parts.
how57
3:40 AM
Weed Ca.
Any pistons or cylinders?
exSW
6:40 AM
United States
No jugs. Do have a used piston which I believe was good but I rebuilt the whole saw from the case halves up and put in a new one. Found two new 501296702 AV's.
5:40 AM
You should try the spring AV on the front of that 266
exSW
6:40 AM
United States
Does the mag tank use a different front AV vs the plastic ones?
Been awhile since I put it together and even longer since I ordered parts. Can't remember why I went all rubber.
oaky
6:40 AM
massachusetts
you selling that metal brake flag? would that fit the 181?
also do you have a top cover for 181/281/288?
how57
3:40 AM
Weed Ca.
I believe the 288 are taller. And bent slightly different. I could be wrong. It’s happened before.
exSW
6:40 AM
United States
Do you want everything I have?
I was thinking it was just the case halves. Build a saw from that if a busted saw comes my way. Sort of a stick em away and wait. Shipping a big box and weight from Kali is $$$
