295 tramp
Hillbilly Saws
- 4:56 PM
- Dec 23, 2015
- Minnesota
The saw was completely tore down except the case and crank. It give it a new meteor piston, caber rings, pin, bearing, seals, carb kit, It has the HDA 120, new base gasket, bar guide plate, chain catcher, I opened up the muffler from the inside at the stock location. and all the components for the G option. Pressure and vac tested. There is a nut to keep the chain catcher secure and a heli coil or insert on the starter right top It's pushing 160 PSI and has only 1/2 tank thru it so far for the break in. I have not tuned it to wood yet still set rich for the break in. PHO 375.00 plus all shipping
