roger collins
- 6:19 PM
- Nov 12, 2018
- ridgeland ms.
i need two - husqvarna part # 503082701
thanks for the info-i tried that source-they said the item was not in stock after i ordered it.
Yes. But needs to be something that's not affected by the heat from the muffler. Tygon won't work. I've had luck with automotive type hosesFor a 2100? I see 501 51 99-01
Does a 2100 even have any 503 pts?
Ah, the front one. Late model has that #. Early one is 501 57 66-02
Can regular hose be substituted?
I'll do some digging among my treasures.thanks for the info-i tried that source-they said the item was not in stock after i ordered it.
I’ve used hi-temp vac line from O’Reileys for impulse line.what type of automotive hose have you used? What about clips?
You can buy spring clamps on Amazon,what type of automotive hose have you used? What about clips?
Think it was some vacuum line I had lying around. I believe I used some thin wire as a tie wire.what type of automotive hose have you used? What about clips?
Think that black Stihl line they used forI’ve used hi-temp vac line from O’Reileys for impulse line.
What about Stihl’s impulse line? They sell it in bulk…approx 3mm
I believe that is what mine looks like and I have two tanks with that configuration.Mine...doesnt look like the ipl pic.
Old style vs newer.I believe that is what mine looks like and I have two tanks with that configuration.
Hmm, now I am second guessing what I have, will have to look when I get home!Old style vs newer.
Ok, both of my tanks are the newer style with the screw in fitting. I just thought I was cool and had the older style...The newer models have a threaded fitting/nipple, 503 08 85-01, that the hose, 503 08 27-01, fits onto.
