Husqvarna 162se
kjmatson
6:56 AM
Hamilton NY
I have a 162 that mechanically is in great shape. I'd like to get it powder coated. I have been cross referencing bearings and seals, it looks like the 262, 372, 372...bearings and seals are a match. Does anyone know for sure if that's the case. Thanks.
82f100swb
5:56 AM
Dryden, ON, Canada
None of the saws you mentioned match. 61/66/266/268/272. 266 I believe has the same carb block and gasket between it and the cylinder. I will have to pull mine apart and double check.
The closest match is actually an early 630 Jonsered. They use the same cylinder.
82f100swb
5:56 AM
Dryden, ON, Canada
Yep, I think the bearings themselves are pretty universal, but seals and gaskets are not.
