For a free IPL (Illustrated Parts List): Briggs & Stratton's official site is the best starting point. Go to briggsandstratton.com/support/manuals (or their parts lookup), enter your full model 125K02-0654-E1, and it should pull up the operator's manual and IPL/PDF parts diagrams directly.
Several third-party sites also offer free exploded-view diagrams (no download needed, but printable):
- Jack's Small Engines: Search the model — very clear diagrams with part numbers.
jackssmallengines.com
- PartsTree or Messick's: Good breakdowns for the 125K02-0654-E1.
messicks.com
- For the Husqvarna 6522SH mower itself (deck, wheels, self-propel, etc.): mymowerparts.com has free PDFs like I0102005 or similar for 6522 SH A/B variants.
mymowerparts.com
These are the closest you'll get to official free IPLs — Briggs doesn't always host everything publicly for older engines, but the above usually works.Hard hot restarts on this Briggs 125K02 (6.75 hp vertical, likely a basic single-cylinder with float carb): Common complaint on these older PowerBuilt/125K series mowers. Since the carb looks brand new and you've avoided E10 (great job — that rules out a lot of gunk/ethanol issues), here are the most likely culprits in rough order of probability:
- Choke/throttle linkage or auto-choke behavior: Many of these have a temperature-sensitive choke that stays open once hot. A warm engine often needs slight choke or prime for restart, but the linkage may not allow it. Check/adjust the throttle cable for full choke closure when the lever is in the proper position. Some people add a manual primer bulb if it's missing.
youtube.com
- Vapor lock / fuel percolation: Fuel boils in the carb bowl or lines when hot, especially if the fuel tank or lines sit right above the engine. Symptoms match perfectly (fine when cold, hard after shutdown). Fixes:
- Insulate the fuel line (rubber wrap, heat shield, or route away from heat).
- Add an inline fuel filter farther from the engine or a small heat shield under the carb.
- Tilt the mower briefly (carb side up) before hot restart to let fuel flow into the bowl.
doityourself.com
- Ignition coil (Magnetron): Classic symptom on older Briggs — weak spark when hot. Spark is fine cold but drops off as it heats up. Test by trying to restart with a wider or narrower plug gap temporarily, or replace the coil if it's original (fairly cheap and common).
smokstak.com
- Other quick checks:
- Primer bulb: Cracked, leaky check valve, or not delivering fuel when hot.
- Float level/sticking float or needle valve (even if carb looks clean — varnish can be invisible).
- Valve clearance too tight (closes up when hot, loses compression). Check/adjust if you're comfortable (specs are usually .003-.005" intake/exhaust cold for these).
- Weak spark plug or wrong gap.
- Air leaks or dirty air filter (less likely if carb is clean).
Quick diagnostic tips: When it won't restart hot, pull the spark plug — is it wet (flooding) or dry (no fuel)? Check for strong spark? Spray a tiny bit of starter fluid into the intake — if it fires briefly, it's a fuel delivery issue (vapor lock, carb, lines).
mytractorforum.com
Start with linkage adjustment, heat shielding/insulation, and a fresh plug + proper gap. These engines are simple and durable — you'll likely get it sorted without major parts. If you need a specific diagram link or more details on a fix, give more symptoms (e.g., does it pop/crank but not fire, smell of gas, etc.). Good luck!
