fdhamlin
My saw is a 2012 with EL44 carb. Last year it sheared the key on the flywheel. As a fix I filed the old key out and fitted a piece of #10 solid copper wire, as it is supposed to be only for alignment (timing).
Used it all summer. In the fall it got hard to start. Spark & compression looks good and fuel is there This spring I tried it again and got a big kickback, enough to shear my copper wire.
Now as I set the flywheel in place aligned with the key slot the magnets appear to be about 90 degrees advanced from the ignition module at TDC.
Can't imagine the crank is somehow twisted Any ideas?
Fred
Fred
