- 5:17 PM
- Mar 1, 2016
- Mid-Georgia
Pretty nifty...
This is cool. I have an AWOL 550xp that is nuts, but always want more, right? Lol
I know all about it.Having to tinker with everything feels like a disease sometimes but it sure is fun!
Does your 545 have decompression valve? I have a 545 mark ll and I’m wanting to do some mods to it but I’m all new to modifying saws just been using them a long time. So I’m kinda clueless on something’s. I’m what you’d mechanically inclined but far from being a mechanic.So everything mostly lines up and most importantly, the locating pins on the 562 intake(Inlet pipe) line up on a 550xp cylinder. I ordered a new 545 since I can't have my 550xp apart during the winter. I also order the following items:
562XP:
Inlet Pipe 520291001
AT55a Carburetor (replaces EL48) from H&L Supply
Flange 505165201
Filter Holder Assembly 505127003 swapped over the switch & air purge hardware from 545
550XP:
Intermediate Wall 522951001
560XP:
Air Filter 505126306
@Filbertlogger85
In some ways, your already ahead since yours is the Mark II: more grunt, latest Gen3 Autotune, and better filter setup. What I'm essentially doing is trying to recreate the MK II on the smaller and lighter MK I platform. The MK II might just need a thinner base gasket and a muffler mod.
Having used a stock 550xp for 5 years, I consider it nothing more than a glorified limbing saw. This is a complete solution down to the stump saw. Here is a Red Oak that I dropped yesterday and I never felt like I needed a bigger saw( trimmed up the butt because I'm cutting it into boards.)
The 545 & 562 look like they both use the same AutoTune module, I just swapped the 545 module onto the 562 carb.
Not really the same, but will interchange as you have done. Has to be done in fact as a 562 module could not be programed to work with the 545 ignition. There are no firmware files to allow for mixing carbs and ignitions from different models.
One question I'd have though is how much of the gains are the result of the carb swap and how much due to the other mods, cause they certainly are contributing to the increased performance.
I was hoping you would reply to this thread. I have a million questions I would like to as a dealer about. I was just going on the assumption that the AT module had to correspond with only that models ignition module. Thank you for confirming that. You know if we had a "Saw College" video about this it would really help out those of use without dealer support.
RANT
I went to a dealer that can work on AT stuff and I bring this in. I buy a lot of my small engine items for the farm here so I'm not completely foreign to them. They quote me half hour labor($40 my cost) and at least 2 weeks to get it back. That's the only thing I don't like about autotune, no local support in this consumer saw market.
I was planning on a step by step modification series but got excited and went full bore with the 545 right out of the box. Right now the 550xp with just the small muffler mod and thinner gasket is has noticeably less torque that the 545/562 setup. Be interesting to see what the 550 does with the larger components.
This answers my other question, cause I had assumed you were comparing the 545 project to a stock 550. I did the thin gasket/muff mod/cut piston skirt build on a 550. Noticably stronger than stock, but your 545/562 recipe must knock it up the torque ladder a good bit more. I'm going have some fun with this. I'm on a bit of a small saw kick anyway right now so the timing is just right.
Have you plugged it in to see how the fuel settings look?
Still no video?
