Brian Carlson
Wanna be saw builder
Trying to get this saw going well and it would start and run good but shut it off and try to restart and it would flood. Found needle in the carb not sealing off. Now when trying to start it the saw backfires through the intake. If you can get it started it runs and idles pretty well but it's a bugger to get going. If the engine has been ran and stopped I can't get it to restart without going to half choke. The cylinder has no scoring and good compression and flywheel key is good. I am thinking it has something mismatched on it from the older ones to the newer x torque. I had one once a guy put the wrong piston in it but it wouldn't run and only backfire. Any help is appreciated.
