- 11:55 PM
- Dec 26, 2015
- The land of pleasant living
I got this saw as a basketcase from a member on this site. Randy cleaned up the cylinder. New meteor piston, new air filter, spark plug, fuel line, fuel filter and recoil. Bought the cylinder cover from another saw. Its setup for a 3/8 because I was planning on porting it, but never got around to it. It runs, idles, and oils like it should. The only quirk it has is when you start it you've got to let it idle for about 5 seconds before throttleing up. If you don't it bogs. Once you do that the little bugger screams til the cows come home. Put about 1/2 tank of fuel through it since rebuilt. I can never envision using it since I have an 026 pro as a limbing saw and I ain't gonna part with that one. Could use the money for vacation this year. Compression is about 155#, and is going to go higher I'm sure. Passed a p&v test when it was rebuilt. $375 PHO or $410 w/ bar and chain. Thanks.
