G
Greenerpastures
Guest
Hi everyone
Oil is coming from behind the bar on my new Shindaiwa 490,
there is so much leaking that it is going to get into the clutch,
it drips and washes up along the side of the bat, way too much
to waste and I don't want it to get into the clutch.
I added a new bar, a groove was cut in the side of the bar so the
oil could flow up it into the hole which in turn leads to the rail
in the bar so lube can get to the chian.
Everything is clean and tight, what can I do to fix this oil from
coming out from what seems to be between the bar and the saw
housing nearest the clutch.
I had this problem before but I upgraded the saw so did not need
to fix it, but was told at that time there is some sort of paste which
is put on between the bar and the saw housing.
Any help would be much appreciated.
Thanks & Regards, john
