NorthcentralYooper
- 10:53 AM
- Dec 24, 2015
- Upper michigan
I'm working on Homelite super ez auto.
I got some spark but it appears weak on plug and tester.
The plug is wet , I cleaned the contacts on the coil. Will get a new plug but I'm thinking it's a points issue with timing. I can clean the plug and put it in and won't even fire once.
I made a homemade flywheel puller and bent that trying to pull flywheel to look at the points. I remade one with heavier steel and I'll try later today .
Has anyone found electronic coils to bypass the points .? I did that on a 012 or 15 stihl.
Any suggestions ?
Any suggestions ?
