Guide Bar for Stihl 084
RomuloTDI
Active OPE Member
2:45 PM
Spain
hello again guys,
I continue with the Stihl 084, for the moment waiting for the new coil, but I am also looking at the question of the guide bar and the chain, my idea was to put a 150cm (60 inch) guide bar but on the web where I buy the bar for my machines they do not there is 150cm for 084, the longest there is 120cm (47 inches) https://shop.saegenspezi.de/Fuehrun...S-880-MS880/120cm-Fuehrungsschiene-3-8-149-16, I have read on the internet (or I have seen it in a YouTube video, right now I don't remember it well) that the blades of the Stihl MS660 are worth it (making the necessary modifications), and in for the 660 there is a 150cm batten https://shop.saegenspezi.de/150cm-S...n-3-8-185TG-16mm-passend-fuer-Stihl-066-MS660, have you made this modification? What other sabers would be worth to my machine?
Thank you.
A greeting from Spain.
Maintenance Chief
9:45 AM
South Carolina
59" bar , specs and part number located at the bottom of the page.
RomuloTDI
Active OPE Member
2:45 PM
Spain
Hi, thanks for your response,
I was referring to whether I can adapt a Stihl MS660 guide bar to the Stihl 084 since the screws that hold the bar to the machine are thicker on the 084 (this could be modified by widening the guide bar slot) and if the guide channel The lubrication of the bar could be modified to fit with the lubrication channel of the machine, it would be to do what is indicated on this website: https://forestryforum.com/board/index.php?topic=87337.0 Has anyone done it?
9:45 AM
I've got a 42" bar from an 066 size milled out to fit an 084 ..Works just fine . I might add that big old saw doesn't see much action .
RomuloTDI
Active OPE Member
2:45 PM
Spain
So, can you confirm that it is possible to adapt a Stihl 600 bar to a Stihl 084?
great.
PS: These days I receive the ignition coil for my 084, as soon as I mount it and know if the machine finally comes back to life, I will put some photos of the machine for you to see
PS2: I finally got the top covers in good condition, they are from the 084 Magnum and they even come with the Magnum sticker, as well as the 084 plate in very good condition.
I'll put photos.
