GBertolet
This is for my 11 hp B&S ringing mower. The governor spring broke on this mower. The engine speed floats if I have the throttle anywhere, other than full and idle. I purchased a new spring, and hooked it up the way I thought it should go. One end on the carb's throttle lever, along with the rod, and the other end on the governor arm. This does not seem to accomplish anything, as the spring is pulling against itself. How is it supposed to go? The manual's diagram does not show where the spring attaches on the governor end. I am attaching a screenshot from my manual. My carb is the left side image.
