hotajax
- 9:03 AM
- Dec 10, 2020
- Eastern PA
I just got a lot of good info from you guys on how to fix something. So, as sort of a "repayment", I'm posting a couple of products you should look into. I don't claim to be an expert, but it is stuff I've been using for a while and find worth the money.
1. VP Fuels Pre-Mix. Ethanol-Free. You can buy it in 50:1 and 40:1 at Tractor Supply ( and other places that I don't know ). You won't have to winterize your stuff, just start it up for a few seconds every couple of weeks in the winter, and they all run fine come spring. Although VP does not say so on the can, I believe my machines have been running much better, like the fuel system is all cleaned out. 94 Octane, too. Significantly cheaper than the brands manufactured by the likes of Huskie and Echo.
2. Trimmer Line: Get Maxpower Twisted line. I had been using Echo Trimmer line with the diamond shape. I couldn't believe how much better the Maxpower works. Very durable, simple to load in a Speed Feed, and cuts furiously. You won't be making as many passes to get the brush cut. It does save you some time. Also much quieter, you won't hear that whipping sound as loud.
Good luck
I don't have any financial interest in either one of these companies.
Good luck
