RIDE-RED 350r
- 9:47 AM
- Feb 8, 2016
- Blossvale NY
So, at work there is an '01 346xp OE. It has been finicky and a bit unreliable and has been replaced by a 550xp.
I asked my boss if I could go through it and do an overhaul.
I got an OE (OEM) cyl kit, new fuel line, fuel filter, tank vent, carb kit, crank bearings, crank seal, updated intake partition and of course the gasket set.
I got it all back together today and it does run, but it isn't tuning in the way it should. It acts just like an 038 Stihl I worked on recently that ended up having a rip in the intake boot. It runs best (but not the way it should) with the high speed jet almost seated and the low speed about 1-3/4 turns out. I should have known better and got the new intake boot and pulse line. Nothing jumped out at me as a problem as I swapped the two into the new partition... Kinda weird, but anyway I have ordered the intake boot and pulse line. I'm thinking that it might not be getting a good seal for the pulse port on the boot where it mates to the carb unless of course I find an obvious issue with the boot.. We have been working our tails off plowing roads all week and I'm running on 9hrs sleep for the last 3 days combined.. Given that, probably not the best day to assemble a saw. But here is where it sits nevertheless.
So I took some pics as I made progress today.
BTW: It looks like I have a couple more saw jobs lining up on the side soon. I plan to invest my earnings in some needed tools for further work like a Mini Mighty Vac, case separator for saws with stuffers, proper flywheel puller and a few other things....
