kjmatson
- 11:15 AM
- Sep 3, 2020
- Hamilton NY
I now understand the big bore kit issue with freeporting. I purchased one for my holtzforma 660 because it is strictly a milling saw. I feel alot better blowing up this saw milling than an oem one. Ive done alot of reading on freeporting and haved herd mixed opinions on it. I have fallen into the opinion of I really don't like the idea of anything getting sucked back into the crankcase if it isn't filtered. Im toying with the idea of building up the exhaust floor to fix the issue. Has anyone here successfully done this considering heat. I've opened the muffler and had a friend make me a sweet cover which helps relieve ALOT of heat problems.
The difference in piston height is .070 being oem is that much longer than the big bore. This difference caused a gap in the exhaust floor at TDC of .0015. I fixed the issue by adding the base gasket back giving me a squish of .043 but id like to get back to the .020 squish i had with the delete. Is the difference in squish that much noticeable I should build up the exhaust floor, or should i just leave well enough alone.
