port1
New OPE Member
- 7:41 AM
- Dec 15, 2020
- Long Island, New York
I'm "restoring" a mint condition Echo EG2300 four cycle generator with a Mikuni Corp. carburetor. I can't locate all the parts for the carb, because the generator is over 25 years old. If it wasn't in near perfect condition I wouldn't bother, but this one is work fixing. I cleaned the carb, but I still need a float and needle valve, and a bowl gasket. Most parts are obsolete. I did locate carb gaskets.
The generator starts up, runs for about ten seconds, then stalls. It does start right up after two pulls right after that. I will be replacing the "low oil" sending unit as soon as it arrives from Ebay. Othewise, I'm baffled as to why it won't continue to run. I'll take the carb apart again. Any advice on where I can locate Mikuni carb parts?
The Echo part number itself is Y16077056010 and there are no other markings on the carb, other than Mikuni Corp. I've tried all the online replacement parts sites and have found some parts, but not for the carb itself. I've even contacted many carburetor repair sites and most have encouraged me to keep trying and not surrender, but I've had no luck. Seems like any Mikuni parts are for motorcycles, Sea Doo jet skis, etc. I'm stuck. Any ideas?
