merc_man
merc_man
- 9:33 AM
- Feb 24, 2016
- southern ontario
So my boy noticed his muffler had a little split so wempullednitmoff and welded it up. Then i figured might as well have a quick look and see how it looks inside. Piston looks ausome. Rotate it to look around bit more and the and notice some scoring on intake side. So i figure better figure out whats going on. Get the mityvac out and find the leak. Intake at where carb bolts up. Pull saw apart to look at intake bellow. Clean it all up and it look good. WTF. Clean the other part up that carb side of bellow goes through and it looks good as well. What the hell. Put back togeather and try a leak test. Well this time it holds presure and vac. Was kinda mind boggled about it then got thinking. I gave him crap a while back for reefing his saw out of a pinch. My guess is he must have moved the intake bellow at the carb enough to cause a leak.
Saw still has 150 psi so glad it was caught sooner then later. If i see him reefnon a pinch saw again i will kick him is the @$$
