Blueacre
OPE Member
- 7:14 AM
- Feb 9, 2021
- Niagara Falls, Ontario
I have an Echo CS590 with 20 inch bar I use for cutting firewood. It is just over a year old – bought it at the local Home Depot – it was the last one in stock and had it on a fall clearance at a great price. I used it first time for 5 or 6 hours last winter - ran great with no starting issues. I only use premium no ethanol gas and I drained all the fuel and ran it till it died before I stored it in the spring of 2020 and pulled plug and put some oil in cylinder. Didn’t use it again until January this year to start to cut my firewood. It was real hard to start when I first got it out. Thought it was flooded so I ended up pulling the plug and cranking it over with no plug in it and then put in a new plug and got it going after quite a few pulls. It ran fine after I got it going so I headed out to cut some wood. Went through the first tank of fuel and ran perfect – cut like new. I shut it off a few times to move between trees and started right up first pull. After I stopped for about 15 minutes to refuel, fill bar oil and adjust the chain tension it wouldn’t restart. Tried for about 15 minutes to start it and finally pulled the plug I had put in earlier and put the original plug back in – started second pull.
Have been using it for 3 or 4 hours a day all week and same thing happens every time. Cold start is usually 4 pull – 2 pulls with choke on and decompression button pushed in and it kicks a little on second pull– push choke in and push decompression button again and usually starts on second pull. Runs perfect once it is going. I can shut if off for a couple of minutes and restarts first pull. If I shut it down for 10 or 15 minutes, which is normally to refuel, it wont start – usually try to restart by pulling choke out and then pushing back in to set high idle – if no start after 5 or 10 pulls try a couple pulls with choke on and then choke off but still nothing – no kick from motor – decompression button never pops out the whole time. If I let it sit for an hour or two it will usually start in 4 or 5 pulls.
I figured it should be covered by the echo 5 year warranty so I took it to the local Echo dealer that does servicing. Paid $35 for a diagnosis that would be refunded it problem was covered under warranty. Got a call a week later that they had checked it and only had 40 pounds compression and in their opinion the piston and cylinder were damaged and would need replacement. Said it had no warranty because it was purchased as a clearance item. (wasn’t told that when I bought it at Home Depot). The dealer wanted 80% of the retail cost of a new one to do the work so I brought it home and decided to pull it apart myself and see what I could do with it. I have rebuilt several GM V8 engines over the years but a newbie to working on 2 stokes. I was looking for a service manual on the internet and found a post where someone else was looking for a manual on this site and Ray Benson had sent one. I joined the site, contacted Ray and he was good enough to send me a copy – thanks very much.
With the manual I had the cylinder off in about 20 minutes – real easy on this model – basically pull top cover, carb and muffler and the 4 cylinder bolts are accessible from the top.
I was expecting to see a lot of piston and cylinder damage inside based on other photos I had been looking at on line. My first time inside a 2 stroke but looked like minimal damage to me.
I have attached pictures of the cylinder and piston
Being a 2 stroke Newbie I would appreciate anybody’s comments on what might have caused this so I can try and prevent it from happening again.
Also any input on the repairs to get it running again. I am thinking clean up the one small mark on the cylinder, new piston/ring kit and cylinder gasket but welcome any comments.
- · The piston has some discoloration on the exhaust side in the ring area and one narrow line that runs the full length to the bottom of the skirt – the discolored area doesn’t feel rough – if I run my finger over the narrow line the finger nail will catch a little so there is some shallow scoring where the line is.
- · The intake side of the piston has a discolored area near the rings – doesn’t feel rough
- · The top of the piston has a uniform coating of carbon – no visible damage
- · The cylinder has a uniform coating of carbon on the dome except for a crescent shaped area in the intake side of the cylinder.
- · I don’t see any damage or aluminum transfer on the intake side of the cylinder wall.
- · The exhaust side of the cylinder has one small area that might be aluminum transfer just below the exhaust port – I circled it in red in the picture – I ran my finger over it and doesn’t feel rough. I am sure that is easily polished out.
