Echo CS-530
mainer_in_ak
4:21 AM
Interior Alaska
This was my first Echo chainsaw. I bought it used from a guy in North Pole who cut firewood consecutively from 2008-2018. I have kept running it as my primary firewood saw since then.
No electricity or oil stove, i burn a fk-ton of firewood hear in interior alaska. Can see below zero in october and even april. Burn wood continuously from august 15th to middle of may.
The saw has only needed rim sprockets, drum bearings, bars and airfilters. It is one second behind my muffler modded echo cs 620pw cutting 12" alaskan birch, in timed cuts. It is alot faster than the neighbors new stihl 261 or my muffler modded echo cs 4910. They have a higher compression ration than a 4910, and rev higher too. Bigger bore diameter
Recently, the flywheel side bearing makes a smidgen of noise, also minor scoring near intake and exauhst.
Saw has now been delegated to cutting canoe trail, which is the most aweful job, plunging in creeek mud, water and debris, until the death of the saw. Muffler opened up and intake/exauhst polished a bit.
Press-fit hardened steel oiler gear, never strips in the below zero weather, like the plastic ones.
This past season, roled a whole load of logs on top of it, when wood sled flipped over.
11.5 lbs dry and clean, on a scale.
Anybody ever run one of these fkn kioritz 13800 rpm clamshell animals?
heritageguy20051
8:21 AM
US
Never ran a 530 but I do have a 520. It's my favorite saw. Bought it new in 2007 and it still runs great.
Sent from my moto g power (2022) using Tapatalk
mainer_in_ak
4:21 AM
Interior Alaska
Your cs 520 is the same saw I'd imagine? Closed quad-transfer ports, very high compression, purdy aggressive port timing, unlimited coil, clamshell in a magnesium case, outboard clutch. Weird little, high-reving monster.
Easy saw to take apart. Id like to find a second one with low use. Its a good party-trick when this clapped-out beat to sht cs-530 massacres the latest/greatest 50 cc saws.
Got the rakers down as aggressive as i run raker depth on a 620 pw. Very little feed pressure, and the things screams through the wood. My 4910 couldnt run that same chain, until muffler modded, and re-tuned.
