Drive link count
jmester
2:41 PM
VIRGINIA
Does any here know what the drive link count would be to switch from 404 to 3/8 on Stihl 14mm mount 084/088/880. Mainly looking for 30" and 36".
dave53223
1:41 PM
Milwaukee wi
jmester
2:41 PM
VIRGINIA
jmester
2:41 PM
VIRGINIA
Based on the chart 91 DL is 6.166 feet of 404 chain. To get 6.127 feet of 3/8" you would need around 100 DL.
jmester
2:41 PM
VIRGINIA
Not sure if that's the right way to do it as I know that 105 DL in 3/8 is a 32".
If I was to buy a couple of loops of 36rs -114 DL that should be enough to make a loop or two for the 30" bar. Just will have to get some presets
8:41 PM
I know You asked for Stihl mount, I can't help You with that.
But D009/large Husqvarna mount true 36" bar is 115DL of 3/8" on a large frame Dolmar with a 7 tooth sprocket.
I don't recall whether an 8 tooth sprocket fits, but I think it does.
jmester
2:41 PM
VIRGINIA
Stihl 36" 3/8 is 114. If I remember right most longer D009 are usually 1 DL more than Stihl.
Been doing some reading on some other forums. Some have said that you would need to add 4-6 more drive links to go from 404 to 3/8. On large 14mm mount Stihl bars
