Dolmar ps9000
saw crazy
Active OPE Member
10:58 PM
Gb
Firstly! thanks for letting me join.
I've brought this saw with running issues and bought a new coil for ps9010 not realising you have to change the flywheel. I've taken the key out and retarded the flywheel and had it running nice. Would any of you guys know how many degrees past tdc the flywheel should pass the coil ? So I can find a better sweet spot.
Thanks again
Shane¹
5:58 PM
Kentucky
I recall someone in the past saying it's 90 degrees difference between the 2 flywheels but if you have it running you must be close maybe mark it try moving it both ways a little and then set it where it runs the best
MG2186
4:58 PM
Summer,IA
Does it pop in the cut? If not advance it until it does then back it off, be a little bit of dicking around but would get you where you need to be
Shane¹
5:58 PM
Kentucky
Did you get this saw figured out?
