Shane¹
- 8:38 AM
- Dec 21, 2020
- Kentucky
Got this dolmar 460 up when I picked that 350 and 510 up a while back. Finally got around to getting a clutch cover for it. Had some marks on the piston cleaned them up and put a new ring in it. Removed deflector and opened up muffler then welded deflector back on. Had a bad coil, found a Stihl coil that looked really similar bolted it up and it fired right up. Advanced timing a little bit seems to run really well. Was going to port these but have other projects going on now. Sprocket was really worn ground the spur down with carbide bit and now a rim sprocket fits nice will probably need a clutch drum if you plan on running it a lot. Looking to get $125 plus shipping. Can come with or without bar and chain
