JimmyT
I have a friend that has worked for Dolmar/Makita for 38 years at the Hamburg Germany Plant. Several years ago he told me that the pistons and cylinders on the 7900RS saws that were built in 2003 had been modified at the plant and they did use the standard 13,500 rpm coil. So I'm guessing that they did a factory port and polish at the plant. My question is what did they do to the pistons to increase performance. Did they use a Kolben piston with 2 rings to increase compression or did they trim the piston skirts. He never said if they used pop up pistons so I'm guessing they just modified the OEM pistons.
