CountryBoy19
Active OPE Member
- 3:21 AM
- Mar 1, 2018
- Southern Indiana
I have a Makita DCS-6401 (ex-HD rental saw) that I've had for several years now. Recently discovered a crack in the crankcase near the left rear anti-vibe mount. So while I have it torn apart to replace that half of the crankcase I'm looking to bump performance. I emailed mastermind from that other forum and he suggested I sign-up and post my question here for all to see & weigh-in.
I have en-route an OEM 7910 P&C to put on. I'm just a firewood cutter but I love to tinker with things. I have a relatively well equipped machine-shop at my disposal (for a home-shop). I don't want to go too crazy on things but what is the low-hanging fruit on these?
I've done quite a bit of reading and I'm hesitant to mess with raising/lowering ports unless I have some good guidance on doing that. I can physically do that, but how do you measure timing? Especially transfers? Do you get your squish set where you want it, install the P&C, and measure the crank-angle at certain points in the cycle?
Things on my list to consider:
Check squish and adjust if necessary (would you recommend doing a pop-up or pass on that for a light port job?)
Widen & smooth exhaust port, especially the transition "lip" left by that recess for the muffler (I assume there is something to be gained there)
Widen intake port (any benefit in changing intake port timing?)
Smooth transfer openings on bottom (I won't have a way to get much inside the transfers or to the transfer ports up top)
Adjust timing? If I understand how this is done you pull the flywheel, file the key off, and manually set the flywheel back on at a certain point, then tighten the nut down carefully to ensure the flywheel doesn't move on the crank? So this relies entirely on the taper locking together correct? What are you torqueing the flywheel nut at to ensure no movement here?
Disclaimer: if there is high risk on these things it's best I stay away from them. IE, if changing intake timing to X has something to offer, but X+1 will kill all the performance gains I won't want to risk going 1 degree too far & killing it all. But if it's something relatively easy, with a little bit of margin for error, I would like to give it a try.
I don't plan to carb mod or change out the limited coil at this time. I can practice the porting/smoothing on my 6401 P&C once I start to tear into this.
I'm a very capable/inclined person that just hasn't worked on porting a saw before so a little guidance would be appreciated.
Thanks for your help!!!
